I am working on a 26’-0 high, single story, religious facility where the main (gravity) load-bearing construction is heavy timber, with glulam columns and beams with a flexible metal roof deck. The shell of the building consists of storefront glazing spanning between site cast or precast panels that are 18’-0 high, 12’-0 wide and located 20’-0 on center. There are clerestory windows on top of the concrete panels that continue up to the roof deck. To be able to transfer the lateral forces from the roof deck to the foundation, I was thinking about building an 8’-0 high +/- moment frame at each panel out of tube steel, with its base at the top of the concrete panels and the top beam connected to the roof deck. I am hoping this frame could be hidden in the mullion space. This structure is in a SDC A, and wind loading controls. Does this seem like a viable means of transferring the lateral load to the foundation? I’ve never had the opportunity to do a mixed system like this before, using material with such different rigidities. Can anyone lead me to a reference or an example so I can feel comfortable that I’m approaching this design properly.
Thanks.
Thanks.
