Hi minimus,
there have been actually some experiences on using old concrete from demolition as recycled aggregate for new concrete. I know this has been carried out in the Netherlands, Spain and Japan. The percentage of substitution of normal aggregate by recycled one is limited because of alterations in resistence, shrinkage, porosity and other properties. But sure you can use it as aggregate in certain amount. You can contact the following groups:
Dr. Enric Vázquez, Dr. Marilda Barra
Construction Engineering Department (Construction Materials Section)
Universitat Politécnica de Catalunya (Barcelona, Spain)
Dr. Kazuhizo Iida, Dr. Shigeyoshi Nagataki, Tatsuhiko Saeki
Department of Civil Engineering and Architecture
Niigata University (Japan)
(Dr. Iida is also at Technology Center of Taisei Corporation)
The Japanese group has also studied the possibility of recycling the fine demolition waste for cement manufacturing.
Some published references are:
Committee of the Japan Cement Association (1998) Effective reuse of the powder produced from demolished concrete. Cement & concrete, Nº 621, pp. 52 – 59.
Iida K., Saeki T., Nagataki S. (2001) An integrated concrete recycling system including cement. Concrete library of JSCE, Nº 38, pp. 95 – 103.
Karlsson M. (1998) Reactivity in mortar phase in recycled concrete aggregate. Use of recycled concrete aggregate, pp. 197 – 203.
Tomosawa F. (1995) Towards perfect recycling of concrete. Cement & concrete, Nº 578, pp. 1 – 8.
van Loo W. (1998) Closing the concrete loop – from reuse to recycling. Use of recycled concrete aggregate, pp. 83 – 97.
Vàzquez E. (2000) Recycling of aggregates in Spain. Proc. International Workshop on Recycled Concrete, pp. 27 – 41.
Winkler A., Müeller H.A. (1998) Recycling of fine processed building rubble materials. Use of recycled concrete aggregate, pp. 157 – 168.
Finally, I strongly reccomend you to search for some experiences in the Netherlands (maybe contacting prof. van Loo, from ENCI, a Netherlands company), because I think they have the widest knowledge about it and it may be preferable for you to contact with companies directly instead of universities. I'll ask prof. Vazquez at Univ. Politecnica if he can provide me any contact and I'll let you know.
Violeta.
