martin888888
We have two situations on our site...
1) 5' Wide Concrete Stormwater Trench that we need to extend 50'
2) 8" Concrete Slab that needs to be widened.
Each will need water stops placed, the concrete pad becasue it is in a chemical spill area.
In both cases would it be appropriate to sawcut each to a clean edge and then when extending to use dowels drilled into the existing end with adhesive instead of rebar? With a water stop needed does rebar give a better seal? My main issue is what is better to use, Dowels or Rebar in making a conection such as these. Just curious to hear peoples takes on this
