ntstr
- Jan 31, 2014
- 2
I am working on a project that contains an open faced precast concrete crib wall that is need of repair. It is approximately 20 feet tall and was built about 30 years ago. The wall is backfilled with stone approximately 4 to 5 inches in size. The majority of the wall appears to be in good shape, however there are several precast members that have been damaged (possibly due to impact loads during floods?) that need to be repaired. I have attached photos of the wall and some of the damaged areas.
I have thought of replacing the end of the damaged headers with a new end cap set in place with drilled and epoxied concrete anchors. Would it be possible to replace the damaged stretchers with new members that span between the stretchers in good shape above and below the damaged stretchers?
Has anyone seen any crib walls with damages similar to this? Any suggestions on repair methods?
Thanks!
Thanks!
