The attached photo is what I believe is a tension failure of a concrete beam. The beam is part of the foundation system for a large round steel storage bin. The beam is located within the outside ring wall where a conveyor/tunnel is located and penetrates the foundation wall. Thus necessitating an opening in the outside ring wall . Can anyone confirm that this looks like a tension failure? For some background, this particular bin foundation is composed a suspended one way concrete slab with intermediate concrete walls every 6 feet and a perimeter concrete ring wall around the circumference of the bin. All interior and perimeter concrete walls are supported on a large raft slab and piles. The perimeter ring beam acts as tension ring and carries vertical loads from the storage bin walls and part of the suspended slab.
I am guessing that maybe the contractor did not install of the correct number of tension tie reinforcement in the beam(contractor error). Any other ideas?
Any assistance is appreciated.
