I am building a piece of test equipment that has five housings (approx 6" OD x 3" thick) bolted together. On each end of the bolted together housing assembly I have ball bearings which guide a shaft through the housings. I am trying to maintain the housing to shaft concentricity as tight as possible. For example, we originally had the housings with an ID of 2.002" and a shaft of 1.999". Upon assembly there is contact between the shaft and housing. This is predictable based on our tolerance stackup as each fit can be up to ~.0007" out of alignment. The answer is not just to try and tighten up the tolerances because:
a) that will be very expensive if it can be achieved. Each housing needs to be machined on each face so it is done in two operations in our NC. The fact that it is clamped/unclamped/reclamped to do second operation makes me think we can't ask for much more than the locational clearance fit we have now. Measurements of the existing parts seem to confirm this.
b) It will be very difficult to assemble if every fit is .0001" clearance on a 4" dia fit.
c) I'd like to do something that is practical on a scale larger than our test equipment. ie: production if we get there.
So, I am looking for your suggestions on how to best design and machine such an assembly. Press fitting the pieces together is an option we tossed around but I still don't know whether it will get us close enough (doesn't address the actual machining of the parts but will eliminate the error with a clearance fit). Assembling them and then boring the housing concentric would help but it is unlikely to be assembled the exact same way twice (clearance fits and stackup) so this likely will only work some times. Dowel pins are nice but sure a pain based on my experience.
I'd greatly appreciate you sharing your input and expertise.
Thank You
Thank You
