casasf
- Dec 11, 2009
- 47
I have a design issue and wonder who can assist:
I have designed a building with steel concentric ordinary braced frame (diagonal). If I need to move the brace away from the column beam connection, there will be an eccentricity on the connection. How far(maximum distance) can I go before considering the brace as an eccentric brace? I am not changing the R values 8 vs 10. The building is designed per UBC 1994. The code is not clear: how far. It only says short distance from the column beam joint. How much is short distance? It does not say.
Thank you for your help in advance.
