Hi all, We have an application to boost/compress commercial nitrogen from ~580 psi inlet pressure to ~590 psi(10psi boost)in a closed circuit for heat transfer application. Operating Temp is ~150-210 deg F. The inlet volume is 800 ICFM at 580psi Can any one suggest what are the options and who makes and which will be most durable and maintenance free units?
Also can I have an approx idea of theoretical BHP need in this application? (I had way off conflicting figures given by some vendors) Thanks in advance ....Raj
