Hi all,
We are experiencing an issue with one of our composite molded products. We are use a bag mold process to form a composite helmet. The layup process is wet on a headform/bladder that is then transferred to a hot mold and cured. In areas where the contour bends sharply we are experiencing resin richness. The Kevlar material is not conforming to the contour in these areas. We have tried numerous combinations of hard pushers, initial curing at low temperatures, etc. with no positive result. We are using a single layer of peel ply on the outside of the layup that appears to act a sieve and does help considerably to remove the resin - the lack of definition of the Kevlar is the biggest current issue. We do not currently have any bleedout/vents anywhere on this particular tool and we are considering their addition as we generally do have them in other tools.
This tool is not dedicated to one particular use - it is a base/insert combination and makes several sizes of product. Bleedout install can be a bit tricky and production volume is low for this item.
Any suggestions?
Any suggestions?
