JPhysics
- Nov 3, 2010
- 1
I am new to Abaqus and Composites so please bear with me the curve is quite steep and I keep falling down.
A couple of basic questions:
1. The best way to "Model" the composite part. I have a SolidModel from SolidWorks and a Surface Model also from SolidWorks, which one should I use and why?
2. Material Properties: The units, no matter which SolidWorks model I use, it imports as mm. Does this mean that all my material properties have to be in N/mm^2? Resutls are then in MPa?
3. I am interested in the Tsai-Wu failure criteria which the help file says is available, but I cannot figure out how to get my output in this format. Any help here?
4. When creating a layup on a complicated section is there any way to re-orient some of the selected faces while leaving the others alone?
