To consider as a composite deck slab (1.5"x18GA. metal deck with Normal weight concrete topping, total slab depth = 4.5") and use the composite deck slab load table to determine the allowable superimposed loads.
The connection of the metal deck to the supporting beam underneath, should it be traditional headed studs, or is it ok to have Hilti Powder actuated fasteners as the connection system and still consider the deck to be a composite deck?
Thank you
Thank you
