BAGW
- Jul 15, 2015
- 392
Should the composite deck in ETABS be modelled as rigid diaphragm or a semi-rigid diaphragm? I know diaphragm needs to be modelled as semi-rigid when there is significant in-plane deformation. What does this mean? What is the limit for this?
Also, ASCE states that a diaphragm should not be treated as rigid when there is horizontal irregularity. My building has horizontal irregularity. So do you think modeling the diaphragm as semi-rigid is the way to go? When I model the diaphragm as rigid vs semi-rigid, the results in the braces are significantly different.
