i am currently working on the design of "concrete-filled steel circular marine piles". as i see most of the CFT research is on building columns but there is no design recommendation or implementation on marine piles.
in case of closed-ended pile driving, one can ensure that required bond strength could be achieved as interior surface of pile shaft is free from dust, oil, paint, organic materials and etc. (this is a similar case for also bored piles with pre-drilling or pre-augering). however, i sometimes encounter marine piles with open-ended because of need of socketing into bedrock and/or relatively larger piles in diameter (say, d/t>=60 and d>=60cm). i am also fine with the provisions in Eurocode4 to make use of them in composite marine pile design but i am not sure if any bond strength can be achieved in case of open-ended pile driving.
any input is appreciated.
