Composite callout for perpendicularity
greenimi
I have a part and I am looking for the right GD and T scheme. I have posted three proposed schemes and I am wondering which one will fit the best for the following scenario:
For performance reasons we must have Ø.100 size holes to be perpendicular to surface C in .010 T MMC.
At this point the drawing is incomplete by intent (surface C is not located properly, Ø.375 not located, etc), but I would like to get your pertinent opinion and to talk a little bit about my proposal datum scheme.
Datum A Ø.500±.003 bore is the one to orient the part into the assembly. Datum target B is the one to stop the remaining translation degree of freedom.
It's kind of strange, but the surface we would like to control perpendicularity from is relativly far away from the feature and because of this reason we have this issue on how to do it right.
1.) Which of these datum schemes it's the best for my goal (or maybe none)? I would say the first one, but what about the next two? Would they have the same effect?
2.) What about inspection purpose (gaging, CMM)? Which do you think is easiser to accomplish, qualify the part per the functionality/assemblability requirements and performance requirements (perpendicularity)
P.S. If I add a profile callout of surface C (relative to A and B)I was told most likely I will complicate the requirements beyond the level of expertise of some people so, I am trying to stay away from that.
And yes, ironically we preffer to use composite callout instead (but,...... if we can stay away from that is even better, so that's the reason is listed only as a third choise :)
Thank you for your help
The easiest way is to add a profile to surface C wrt A(M) and B, but then nobody will understand , here, what that means, and how that supposed to be measured and more importantly that the simultaneous requirements kicks in (to mentain perpendicularity in a desired acceptable condition)
