yusf
- May 9, 2006
- 58
Hello All;I had asked same in composite platform but again i would like to kindly ask here too..
My question is especially in the field of testing of composite materials and making use of the datas obtained from those tests.If i test a 2.5 mm thick specimen and get result how can i use the faiure data obtained from test for my let's say 3 to 5 mm thick composite design.Sould i perform other specimen tests that are in 3 ,4 and 5 mm thick? in order to model all thickness region as single lamina in ABAQUS.?Should i perform analytical lamination theory to find each individual layer propertis by guessing until precise EXX EYY at which the whole laminate appearent modulus equals to the test value? AND THEN modelling other thick regions by calibrated EXX EYY?Any idea? thanks in advance...
