We have specific colors that must be applied to specific components to fulfill one of our project requirements. Once this is done, the file is exported as a .jt file for use in Vis Mockup. Colors are being applied to the solid body, sheet body, and component in the NX Assembly. When I bring the .jt into Vis, all of the component colors have changed themselves. Is there a setting I'm missing? It has to be exported as a .jt file to carry the meta data into Vis Mockup. Or is this perhaps a setting that needs changing on the Vis side?
Thanks in advance.
Thanks in advance.
