Component SRS Testing
tomirvine
Certain electronic components must be subjected to shock response spectrum testing, particular if the component must survive a pyrotechnic shock event while in service. (Refer to MIL-STD-1540, 810, etc.)
I have an idea for a new type of shock test machine:
One of the advantages of this method is that it lends itself to mathematical calculations (in contrast to most SRS test methods which are black-magic).
I currently do not have the resources to actually build this machine. But a simple, subscale prototype would be easy to build and test.
Anyway, I am available to collarborate with anyone who wants to develop this machine. This project could readily result in a conference paper, and hopefully a commercially practical test machine.
Tom Irvine
(P.S. Don't forget the analog anti-aliasing filter.)
Hi Tom,
I gave a quick run-through of your paper. I'm assuming you want to build the machine off of the design concept presented in the paper, although more detailed of course. I can design the machine on Solidworks (even test it if necessary) and have a machine shop build the precision parts if needed. I have experience in acoustics and structural dynamics as well.
Go through my website below to get a hold of me if you would like to have further discussion.
Kyle
Kyle Chandler
Tom,
It looks simple, but other than orientation and energy source, how is this different from a Hopkinson bar test? Sandia has done a lot of work using them for pyroshock simulation.
Jim Kinney
Kennedy Space Center, FL
Yes, that is my question also. It does seem similar.
Kyle,
This idea is not ready for SolidWorks. It first needs to be tried out using a subscale prototype made from hardware store parts. Thanks for your offer of help anyway.
Jim,
This idea is very similar to a Hopinkson's bar. The excitation source is different as you noted.
One of the ideas of this project is to compare the responses from force excitation versus initial velocity excitation of the bar/rod/pipe/beam.
My career opportunities have taken me away from hands-on testing to straight analysis (for better or worse), so I do not have ready access to data acquistion systems, accelerometers, etc.
But this would make a great science project for someone, as I mentioned previously.
Tom Irvine
I know that, I just like putting things together on Solidworks before I go buy parts. Coming across the data acquisition system and components, well that's another problem. Knowing someone in a general lab will help.
Kyle Chandler
