Compeletly Separation Water from Hydrocarbon(H.C.)
  • Thread starter Thread starter -
  • Start date Start date
Guest
In an overhead system accomulator of a vaccum tower it is nesessery to separated water compeletly from H.C.;We must be certain that H.C. free of water(water content is trace).
Which process Equibment & control you are suggest to preventing water carryover with H.C.? Water must be exactly sparat from H.C.;
In simpie System floter,level indicator, may be wrong and indicat uncurectly.
System Condition: Temp:50C Press: 0 Barg
H.C SP.GR:0.855
Best Regards,
Najm
You have very heavy hydrocarbons with very little water to begin with. You want to remove more water. First, decant off any free water. Next, raise the temperature and boil off water what you can. I don't think mol sieves are going to work because they will plug quickly with your heavy HCs. That may be the limit of what you can do without knowing more details.
Have you considered using a coalescer to remove the water? You could pump the HC/Water mixture through some type of filter/mesh and allow the water (since it is heavier) to drain to a lower section of the coalescer to be pumped away, while the HC pump straight through and are sent out through the top.
I've installed a similar system before. You should be able to use a capacitance probe with an automatic shutdown system to detect water in the upper reaches of the device (where the HC will be exiting) to further secure against carrying water through.
Hopefully this is relevant and helpful. :)
