In a technical paper of DIPRA they say that ASME B16.1 flat face class 125 flanges are compatible with ASME B16.5 raised face class 150 flanges if the raise is 0.06inches.
Previously, I was told that steel raised face flanges are not recomended with cast iron flat face flanges, since there is a risk of breaking the iron flange.
Does somebody know more about the subject?.
I want to use flat face cast iron flanges conected with raised face steel flanges for a fire protection system and want to know if there is an important consideration I should take on account (about the bolt torques, tipe of gaskets, etc) or if I can follow the same requirements as if I were using steel flanges).
Thanks.
Thanks.
