What is your mechanical load (power, speed, ..)
What is type of DC Motor, separately excited, shunt or series?
It depend on your mechanical load (Power and speed), then you can select Ac Motor suitable for your mechanical load
· If your load needs constant speed regardless variation of load or electrical power supply, then use Induction motor with variable frequency control
· If your load normal, does not need constant speed, then use Induction motor with normal AC supply
