In your application (indoors, surfaces cleaned regularly) , I believe the 201 material should work just fine. Have you reviewed corrosion test data for this alloy? I've tested 201, 201LN, and 304L side-by-side in ASTM B117 chamber and they all look phenonmenal after 1000 hrs (painted, scribed, and bare). I think this test environment is pretty harsh compared to your application. If 201 performs this well, the next lowest cost approach in my mind would be to investigate using a ferritic grade with a clear coating.
