I search for Compact high-pressure centrifugal pump to handle flow rate in the range of 5000 BPD & discharge pressure in the range of 3000 PSI with suction pressure 50 PSI but the restriction point will be the area as this pump will be installed in offshore oil and gas platform with only 3M*3M available space, is that available in market, or I must go to positive displacement pump.
