aquilajohn
Industrial
I am hoping to find help with understanding ( and perhaps eliminating )a problem with unusual ( to me anyways ) wear on small AC motor cxommutators. The motors in question are rated at 120VAC 0.9A (95 watts) 50/60 cycle 3500RPM. What has me confused is that the commutator pads wear unevenly with every other one becoming pitted and rough. Thus high arcing / heat and the need to clean and resurface the commutator and reseat the brushes. I have checked for runout of the commutator assembly / shaft, brush bounce / tensioning springs / holder tolerences, etc. Then became aware the problem is consistent from unit to unit.
I am at the point that I suspect the design may have something to do with it. Is it possible, by design, that every other pad would be subjected to different forces (electrical) than the alternating pads. The pads that are not quickly becoming rough look perfect. The brushes seat cleanly at first but within 3-5hrs become rough and groved. At that point the pads reveal this every other pad pattern. A smooth polished pad, then a rough one, and so on. The motors application requires low torque loads that are even and consistant over time so current draw remains smooth and even, at below 60% of rating.
Any help offered would be most appreciated as I know little to nothing about AC motors.
