AMontembeault
We're having a bit of a debate here at work.
Suppose I had a piece of plate with 2 holes in it. Each hole is specified as a datum (in this case, datums B and C, where datum A is the large flat face of the plate).
I have another feature with a positional tolerance with respect to A and a common datum defined by B and C (B-C).
The question we're debating is if B-C defines 1 datum wherein the axis of both B and C must lie (call it a horizontal datum), 1 datum between the axes of B and C at an implied center(call it vertical), or actually 2 datums orthagonal to eachother (controls both the horizontal and vertical datums).
Previously, we've been operating under the assumption that it only defines one plane, however reccently I had a conversation with an outside source that claimed that because the datum simulator would basically be 2 pins, it in fact defines 2 datum planes. Unfortunately, I cannot find an example in either the ASME GD+T standard or the ISO standard which can confirm or deny that either way is factual - almost every example I've seen only relates to 2 planar surfaces or 2 nominally coaxial surfaces, not 2 holes at some distance apart. Could anyone shed some light on this, or perhaps show me a published example?
Thank you
Thank you
