GD_P
- Apr 6, 2018
- 128
Hello community,
I have a doubt, please do share your opinion. In the attached file, right side picture indicate 4 small shop fabricated structures (3m x 3m x 6m high) A,B,C & D each having 4 columns, single storey. These will be shop fabricated, along with the chemical process equipments, piping & accessories and installed on site adjacent to each other in the same manner as depicted in the right side picture. The column bases are modeled as pin type connection and lateral force is resisted by knee bracings.
My question is about the base plate which is common for 4 columns where all modules touch each other i.e., detail ‘P’ which is shown in the left side picture. For all 4 columns of detail P base plate is common & which is modeled as pin type. But as you can see due to practical constraints, it is not possible to weld from one side of every element of column ( flange, web) neither possible to provide anchor bolts in area generally made for single column base plate. There is no uplift at the column base for any load combination. With this scenario, if the available weld & anchors are adequate for required shear, will this be enough to call it as pin type base. I am using Eurocode.
One more point, here the column bases will be bearing against the base plate, so as per the EN 1090-2 tolerance, the angular tolerance for bearing type columns is given as depth/1000 = 120/1000 = 0.12 mm (for HE120A sections). Isn't this too stringent and will have to end mill to achieve this or my interpretation is wrong?
Sorry for such long post.
Thank you.
GD_P
Thank you.
GD_P
