jhonsom
- Nov 13, 2009
- 32
The relay has following funtions: distance, v/hz, synch check, auto synchronism, undervotlage, reverse/forward power, loss of field, negative sequence, overcurrent, time over current, over voltage, stator ground fault, out of step, frequency relay, current/ground differntial.
Should we write in literature/ manual of the relay how to perform commissioning test for all the functions. Does any body test these funtions in the field? what are the critical commistion test for the relay?
