Hi everyone,
I have been working on a load combinations tool for CSI software. The purpose of this tool would be to make the creation, modification and checking of load combinations a very easy and non-time consuming task. This tool will be open source and free.
I have already laid down all the pipe work (API calls etc) and most of the functionality but wanted to take people's opinion on the features they would like to see.
Current features include but not limited to:
[ul]
[li]Modification of a single or group of load combinations easily. Add several load cases or load combinations with a button click (think of adding a group of load cases to an envelope load combinations which is a very time consuming task).[/li]
[li]Import load combinations from any CSI software. This allows you to drag any CSI software file and have the load combinations imported which includes mapping the load cases (with different naming) to your model and creation of any extra load cases required.[/li]
[li]Generate automatic load combinations. This allows the user to define load combination (load cases with factors) for a certain code and have the "config" file saved to auto generate load combinations easily. The user would be able to control what load combinations are considered for "Dead", "Live" etc.[/li]
[li]Print load combination details. This allows you to print load combinations into a clean pdf to be included in your report or to review when checking a model.[/li]
[li]Check load combinations. This includes doing quick customizable checks like checking for certain load factors if they are outside a certain range or checking your load combinations against defined load combinations.[/li]
[/ul]
The plugin has an improved interface to view your load combinations list with the ability to filter your view or search (Main Window GUI).
What features would you like to see? What issues do you face when creating and modifying load combinations? You can provide text explanation or mention a feature in other software you would love to have when working with CSI software.
The tool is built using Visual Studio + C#. The GUI is built using WPF. If you would to like to contribute and have the skills to work with C# and WPF, please reach out. The project is hosted on github and is private until the release.
Thanks!![[bigsmile] [bigsmile] [bigsmile]](/data/assets/smilies/bigsmile.gif)
[ul]
[/ul]
Thanks!
