For various dimensional reasons I need to create a built-up beam. I have a W16x36 --below it is a W18x40 and the loads are applied to the lower flange of the W18 beam. I have calculated the required fillet weld to handle the transverse shear as calculated from SCM eq 1-1 (pg.1-7 SCM14). I can weld around the flange of the smaller beam to the larger beam. However, I would be concerned about the flanges flexing under loading and causing rotation at the weld root. Therefore I am proposing using the weld to handle the transverse shear and bolts spaced every 14 inches to handle the direct shear and prevent flexing of the flanges about their weld roots.
Bolts alone are not a good options as they have to be SC due to reversing load conditions. I would need a large amount of bolts.
I attached a graphic. What are your thoughts? Is this a sound approach?
