Hello all,
Quick question for anyone who can help clarify something for me. What is your approach for combining the Fb & Fac of a composite section that utilizes the same material (same modulus of elasticity). I am familiar with the transformation of (2) materials to a single material, but that isn't the case in my situation.
Example:
Consider a hollow steel section with a calculated Fb. Now consider an steel insert, whether it be a hollow tube or solid piece, with a different Fb (same Modulus). Assuming the NA of each section is aligned, I can calculate and combine my section properties or determine them from a shape building program. What's the method for combining the Fb1 & Fb2 in relation to the section modulus to determine my allowable bending moment (M=Fb*S). I have not listed actual stress values because I don't want to complicate or deviate from the principle of this question.
Thanks!
Example:
Thanks!
