sanjaychetan
IN PLATE GIRDER DESIGN OF WELD JOINT BETWEEN WEB AND FLANGE,VARIOUS STANDARDS AND BOOKS LIKE GAYLORD,MUKHONOV ETC REQUIRE THE JOINT TO BE CHECKED FOR ONLY SHEAR FLOW AND VERTICAL SHEAR DUE TO ANY CONCENTRATED LOAD FROM FLANGE TO WEB(IN CASE WEB IS NOT MILLED ).MY DOUBT IS THAT THE WELD WILL ALSO BEND IN THE SAME RADIUS OF CURVATURE AS THE WEB TOP OR FLANGE'S WEB SIDE SURFACE. SO BENDING STRESSES SHOULD BE INTRODUCED IN WELD AS WELL.SO WE SHOULD CHECK THE WELD FOR COMBINED BENDING AND SHEAR STRESSES.BUT THIS IS NOT REQUIRED AS PER STANDARDS. I GUESS I HAVE GOT IT WRONG SOMEWHERE BUT CAN'T FIGURE IT OUT. CAN ANYONE PLEASE ENLIGHTEN ME ON IT AND SUGGEST SOME REFERENCE?
