MrRogers1987
Aerospace
I'm using 1D COMBIN14 elements to connect coincident nodes and manually control the stiffness between them for each DOF. The orientation for each spring is based off the nodal coordinate systems of the nodes defining it according to the ANSYS manual. I want to know the forces between these two nodes in a local coordinate system so I aligned the nodal systems with it. When I run my model it behaves as expected, but when I try to recover the forces in the spring elements they are clearly incorrect. In the manual says that if your rotated nodes are not rotated in precisely the same way that force equilibrium won't be maintained. I tried rotating the nodes using both nmodif and nrotat (separate attempts) to ensure that they had "precisely" the same orientations, but it seemed to make no difference. The only time the forces would come out correctly was when there were no rotations applied to the nodes defining the springs.
Is there some other way to define the element orientation that will not inhibit its ability to maintain force equilibrium? Or alternately, is there some way to translate the element forces from the global coordinate system into a local coordinate system after solving?
