@HTURKAK: Excellent contribution on this. As I'm prone to doing, however, I'm going to question some things.
HTURKAK said:
The roof columns connected with spandrel beams all around , that is the intermediate roof columns at facade (except corner columns) will have beam conn. only at one direction.
1) I suspect that this was the source of OP's original discomfort but, frankly, I don't see it as an insurmountable issue. In the global sense, the frame will require lateral stability at the roof level. That's okay though as there should be a competent, and apparently discretely braced, diaphragm at the roof level for this function. For the local / torsional stability of the roof beams, it would obviously feel better to have those tied into a concrete roof slab. This is, of course, non-mandatory with the right beam proportions however. I'd expect a capable designer to do exactly as you've done in your latest sketch: make the beams stocky to preclude torsional buckling issues. Most codes will also have some minimum requirements for beam stockiness when plastic hinging is anticipated.
HTURKAK said:
Another issue, due to storey ht, it is hard to provide strong column-weak beam concept.
2) One thing that will help to mitigate this is that is generally not necessary to enforce strong column / weak beam behavior at roof levels.
HTURKAK said:
iii = Provide bracing at top chord level only at one bay.
3) While I agree that some optimization may well be possible, I think that a stiff and capable diaphragm is critical here so I'd not be scrapping too much of it. In fact, as shown below, I feel that some additional node points on the left and right may be in order.
4) HTURKAK said:
v = The truss base plate - column conn. should be pin conn. provide slotted holes at one side.
4) What is the basis for your recommendation. Per [1], I feel that it is important that the roof trusses laterally brace the tops of the columns. They can't perform that function with slotted holes at the connection.
HTURKAK said:
iv = Provide perimeter tie beam at intermediate level.
5) I had the same thought, initially, but am conflicted having thought about it in greater detail:
a) It feels good to have some extra joints in the upper story to yield and dissipate more energy.
b) It feels good to reduce the slenderness of the tall, upper story columns. That only helps in one direction of course.
c) While it feels good to create sort of a faux uniformity of story height in this way, it must be remembered that it is really the
interplay of story mass and story stiffness that we're trying to manage rather than one variable or the other in isolation. To this end, having a light story (steel roof) combined with a flexible story (tall columns) might actually be beneficial for creating a uniform shear building response up the height of the structure. Admittedly, this is something that is difficult to "tune" reliabley.
d) At the end of the day, I suspect that OP is stuck with some kind of vertical irregularity with or without the intermediate framing level.
