Columns - HSS or WF
JAE
15,591
What are most of you specifying for general steel framed buildings - primarily industrial/warehouse types?
We generally see a lot of wide flange columns used in these kinds of buildings but when you look at the relative weight-stiffness and weight-strength ratios, the tubes look very good.
But if so, why do we see so many WF columns used?
The argument put at me is that even when comparing strong axis bending the tubes are better per pound.
I'll spot check a few shapes tomorrow and see.
I think that is correct if you compare a square tube with a square WF, but with a "beam shaped" WF used as a column, not so.
Multistory is a different can of worms... HSS come into their own when column height exceeds 10' or 12'... and, I agree, that for multistorey stuff that WF is generally better for ease of connections.
Brad...
Cost per pound is just a little higher unless you are looking at unusual section sizes and the steel has to be 'warehoused' sourced in which case the cost for HSS is markedly higher.
Dik
dik, at one time HSS used to be around $.5/lb compared to $0.35/lb for rolled sections in my area. The fab costs always seem to be more for HSS too. I have not priced any lately. Most of the time the Arch never wants things sticking out of his 6" walls, so HSS usually works best. I am talking two/three stories.
Brad
I got complaints on the cost of a 2 story jail that was cost estimated prior to bidding where I had specified HSS columns instead of WF about 5 years ago. We switched to WF and saved a lot on steel cost, I have since left it to the architect to decide if they really want HSS on any building or else I suggest using WF. It may not always be the case on cost depending on the size of columns you are comparing. I understand some HSS shapes are more expensive than others.
