How do I analyze a column like truss?
I tested the main lines with the total length and the bracing connected to the main lines but the calculation exceeds the capacity ratio
However, I see many structures with these sections and I decided to try dividing the column into several sections in which the bracings coincide and the calculation does not exceed the capacity ratio, then what is the best methodology?
