Can anyone direct me towards a hand-calculation method for designing column base plates for biaxial bending? So far, the only thing I've found is an equivalent uniaxial method used by STAAD etc. The plate thickness appears reasonable with this method, but the anchor bolt requirements do not. I'm developing a spreadsheet to do column base plate, anchor bolt, pedestal and footing design for up to 25 load cases, otherwise I'd simply purchase existing design programs.
The only other method I can think of would be the Bresler reciprocal method. 1/Pi = 1/Pnx + 1/Pny - 1/Po
Another question, how accurate/valid is the AISC method for designing base plates with uniaxial moment? Aside from a finite element approach, is there a more accurate/valid method?
Any help would be greatly appreciated!
