calemadsen
I'm affixing steel columns to an 8inch concrete wall to support a roof structure. The columns will see a rather large moment compared to the compression load because of the span that is involved--about 350 kip inches in moment compared to 13.5 kips axial (compressive) load. I've selected W6*25 columns to connect to the base plate (which is welded at the top to a W12*19 beam), and am having trouble deciding the plate thickness. I used the AISC procedure ( for column base plates with high eccentricity, but the problem is that because the base plate is restricted in size in one dimension (the 8" width of the wall) the 'critical section' about which the bending is to occur is outside of (or closer to the face of the wall than) where the anchor bolts should be to maintain the embedment I'm hoping for, i.e. 1.5 inches. This seems like a problem to me--is it?
The numbers otherwise work out and seem intuitively reasonable. However, I don't feel confident in the base plate thickness that is given because it seems that the moment for an inch wide strip is likely incorrect.
