column base design for a cantilevered column 1
MRberkeng
3
HOW DO I DESIGN THE BASE PLATE FOR A CANTILEVERED COLUMN. IVE TRIED SEARCHIMG THE AISC MANUAL BUT IT ONLY COVERS A AXIAL FORCE BASE DESIGN. CAN ANYONE SHOW ME THE CORRECT WAY. THANKS
The steel book by Salmon and Johnson has base plate design, as does the book by Blodgett. AISC also publishes a column base design guide. I would start with the AISC design guide.
The ASIC publication deals with axial load, small moment and large moment... Your problem would fall under the large moment and they have a couple of worked examples in their publication.
Dik
FYI, the AISC publication is called "Steel Design Guide 1, Column Base Plates".
I made a spread sheet from an example by J.C. Smith. The procedure is similar to the design of retaining walls. When e>B/6, tension in the bolts is required for stability.
I have the Salmon and Johnson book, but I didn't know they addressed this. I will have to check it out.
