ConstantEffort
- Dec 29, 2012
- 72
Distillation column and an independently-supported, vertical thermosyphon reboiler parallel to the column.
The reboiler is on its own structure to support weight. It is free to slide though to accommodate the thermal expansion between it and the fixed column. This also means that wind and seismic forces from the reboiler will transfer across to the column.
We buy out these vessels from different suppliers. To date, no one has really thought about the interactions between the two. That is to say, the skirt calculations on the columns only consider the overturning moment of the columns themselves.
How do you address this situation?
Am I off base to think that the column should be designed to handle the combined reaction?
Does anyone sub the whole package out a single vessel shop which takes full responsibility for both vessels and the pipe between?
