Colour printing a SW Drawing not assembly or part 5
yvonne
Industrial
Sep 14, 2002
22
Hi is it possible to print a colour SW Drawing? So far I can print colour assembly drawings but not template drawings
yvonne
Shaded View will print in color (assuming you have your printer setup right). If you want to keep a wireframe display, but have each component in a different color then you'll have to separate the components in different layers. There's a macro at:
called layout.swp that will do all of this for you.
Ken
Do you wish to plot / print in a similar way to an ACAD line drawing?
If so, you can assign components and lines to layers and assign the layers a colour (and linetype) within the layer dialog box.
To assign a component to a layer, either right click on it in the Feature Manager (under a dwg view) and select Component Line Font, or click on the part in a view and select a layer to place it on.
Other lines (projected geometry or normal sketch lines, text, dims etc) may be assigned colours using either the line type tools, or by assigning them to layers.
Make sure that the colour display mode button is toggled correctly.
Hope I'm barking up the right tree here...
Chris
You might have the print settings set to force black-and-white. Check the Page Setup button button on the print control panel and see which radio button is set under Drawing color.
[bat]"Great ideas need landing gear as well as wings."--C. D. Jackson [bat]
kenbolen,
the web site that u 've given is not correct. spelling mistake.
this is correct website name.
very nice web site.
they 've given some free macro and api tips also.
its really very nice... they 've given lot of links also..
thanks kenbolen...
regards,
murugan.S
Design Engineer,
GlobalSoft Pvt Ltd,
New Delhi, INDIA,
murugan_subham@yahoo.com
