Colour of plot...not based on z coordinate, but on other variable. 1
autOverzicht
BE
Hi
I plotted an hyperbolic parabolid surface in Matlab. The colour of the plot is based on the z-coordinate of the surface. But, now I want to visualise the result of an other function (like: f= x+y+2) on the the surface. So the colour of the surface should be based on the result of function f and not on the z-coordinate. Can somebody explain clearly how to do this? Is it a 4dplot?...and/or how this exactly works?
Thanks in advance!
k = 1
x = linspace(-3,3);
y = linspace(-3,3);
[x,y] = meshgrid(x,y);
z = k*x.*y;
mesh(x,y,z)
I was curious about this so I looked into it & it's pretty straightforward, actually. You can add a fourth parameter to the SURF command to color the surface. In the case you've presented:
Code:
k = 1
x = linspace(-3,3,50);
y = linspace(-3,3,50);
f= x+y+2;
z = k*x.*y;
surf(x,y,z,f);
shading flat;
Hope that helps. Here's a picture:
download.aspx
Link to picture.
Good luck!
