Color on assembly
  • Thread starter Thread starter MichailS
  • Start date Start date
M
MichailS
Guest
Hello
Is there a way to assign a color to an entire assembly in Inventor? Without having to "paint" every individual part?
The parts get their color from the material styles, but at a certain step in the manufacturing assembly process, the assembly is painted.
It would not be correct if I applied the color to the parts individually by changing the style, because that messes with the visualisation of the sub-assemblies.
Thank you
All right - figured out how to do it.
First select the components, THEN choose a color.
A bit different from ProE.
