exnavynuke
Industrial
Hi all,
We are experiencing a vicious and repetitious silica problem at this relatively new power plant. It has been an intermittent ongoing problem.
Plant design: 2x1 GE gas turbines into one GE steamer. HRSGs are triple pressure reheat. Demineralizer is Cation, anion and mixed bed. No pre-filtration of the raw water, which is supplied by the local water district from wells.
Here's the problem: If we run base load or less, silica is under control. Operating HP drum pressure is 1100 psi or so. Whenever we fire duct burners to increase power output, HP drum pressure goes to 1800 psi, and suddenly silica starts appearing. It can get bad, like up to 50 ppb in the condensate.
We aren't seeing an increase in hardness or conductivity in the drums, so we don't really suspect a condenser tube leak. Besides, we had a contractor perform a helium on-line leak test recently.
It's my understanding that subsurface waters don't generally have colloidal silica, but based on what we've eliminated so far, it looks like we're down to that.
The suspicion is the colloidal is in the boilers unreacted, until the duct burners break it down into reacive silica when we go to high power.
Question: Does anybody know what temp/press causes significant breakdown from colloidal to reactive? This would really help confirm what we suspect. I've hunted all over the internet for this and can find nothing.
