Any lens could get stressed over time or due to cooling issues. This could then affect your mode quality, which will affect your cut quality. Easiest way to check for stress in lenses is to use polarizing filters. Actually Krugtech tip on using a LCD screen as backlight, and only one polarizing filter works really well. If you have a constant uniform color, the lens is good. If you see discolorations, spots, cross-type shade through the polarizing filter, the lens is stressed.
