Hey guys. Looking help with a problem I have. I am an Environmental Engineer installing a potable water supply for a meat processing plant in N.Ireland. We have drilled a borhole and are testing the water for use in cleaning and washing of plant equipment. The water quality standards for potable water (UK&Ireland) recommend that no coliforms be present in the water supply. However when tested, the water is giving results 7 cfu/1000ml for the 1st test and 11 cfu/1000ml for the 2nd test. The owner has went to considerable expense installing the borehole to a depth of 80m through the underlying limestone bedrock. I have suggested that they maybe create a holding tank facility for the grounwater and treat the grounwater with UV/Chlorine, but again this will lead to considerable expense on the clients behalf. I was wondering if anybody had experienced similar problems, and if so how it was overcome. Any help would be appreciated.
