cold pipe cutting
32
Dear Engineers,
We will cut some pipeline using cold pipe cutter machine.
Does somebody know what standard should we use ? ASME codes or other standards
Praz
ASME codes and standards is perfect guideline for cutting pipelines and some other task in mechanical engineering. I think you can use that with your project.
________________________________
plumbing
Is it a steel pipe? what is the size and thickness? I haven't seen large pipes to be cut by cold cutters. I guess the most important is the surface finish of the pipe to meet your joint requirement.
