"Programming today is a race between software engineers striving to build bigger and better idiot-proof programs, and the Universe trying to produce bigger and better idiots. So far, the Universe is winning."
Note that the slender ratio is only a practical index. When it goes beyond the recommended limit, the allowable stress/strength will be too small for practical purposes. You can calculate the resultresulting allowable stress/strength by using any code provided formula/equation for compression to get a feel.
Retired13, are you sure? Seems like a big statement to make. Wouldn't the slenderness ratio be a way to control second order effects within a compression member.
In 1999, the AISI committee removed the KL/r limit (of 200) from the code. I think their reasoning was that (at that slenderness ratio) you'd wind up with such a ridiculously uneconomic design with Cold Form that there was no reason to include it.
You can still find the kl/r≤200 recommendation in AISI S100-16C. I stress recommendation because if we're talking about a member with, say, a kl/r of 205 that is seeing extremely low compression stress and no bending, I'd probably run with it.
