In ASCE 7-05 and 7-10 Table 12.2-1, I use "Steel Systems not Specifically Detailed for Seismic Resistance" with R-3 as my seismic force-resisting system whenever I can. My question is, does "steel" refer only to structural steel? Or, can cold formed steel (CFS) systems use it too? I have CFS walls with flat strap bracing resisting my lateral forces. This option is included within "Bearing Wall Systems" (although, not included in "Building Frame Systems"), but like I said I would prefer to use the system not specifically detailed...
I understand that sometimes "steel" can refer to either structural steel or CFS; sometimes it is meant to apply only to structural steel. How does it apply in this case?
Thank you,
--Matt B
Thank you,
--Matt B
