chisa3
Chemical
- Jan 15, 2008
- 3
I am doing a review of our PSV settings and have found the term "cold differential test pressure" on some of the data sheets. When reading definitions of this, I have seen that it is an adjustment to the set pressure of the valve when it is being set, as it is not at process conditions.
The definitions say the correction can be due to backpressure and/or temperature fluctuations. I understand the point about back pressure, as you have no backpressure on the testing bench, so you must correct for this.
I am, however, trying to figure out how the temperature will affect the lifting pressure. I thought it may be to do with the spring in the valve changing resistance at elevated temperatures, but this sits on the non-process side of the valve, so don't think this can be right?
I would really appreciate it if anyone can explain this to me....
Thanks for the help
Alex
Thanks for the help
Alex
