Coiled Tube HS-90
AEW
Hello all,
What does the prefix HS stand for in the Coiled Tube HS-90 manufactured by Tenaris Coiled Tubes?
Could anyone provide the magnetization curve (B-H curve) of the Coiled Tube HS-90, which is made of the steel alloy A-606 type 4 molly?
Thank you.
HS- high strength
This alloy is normally desgined for magnetic applications, plus, B-H curves depend heavily on status of alloy. One might be hard to find a BH curve is readily available.
Is there at least any B-H curve of reference that can be found perhaps in materiel books?
There was a typo in my previous post, the alloy is NOT designed for magnetics.
you may find a hysteresis loop from a low alloy carbon steel as a reference.
