Excerpts from USS application guide:
Core loss separation:
In some design applications, it is of interest to separate the total core loss into two components, the hysteresis loss, Ph, and the eddy-current loss, Pe. Since the hysteresis loss per cycle of the excitation field is proportional to the area of the static hysteresis loop, it is convenient to relate the hysteresis loss to static loop parameters such as coercive force, Hc, and residual induction Br. Specifically, the hysteresis power loss is:
Ph=0.01445(?fBrHc) watts per pound
D
Where:
f is the excitation frequency in Hz
Br is the residual induction in kilogausses
Hc is the coercive force in oersteds
D is the density in grams per cubic centimeter
? is the hysteresis loss factor, is the ration of the actual hysteresis losses to the area of a square hysteresis loop passing through Br and Hc.
Eddy-current losses are due to energy dissipated by circulating currents induced in the core by the alternating magnetization. For laminations, eddy-current losses can be obtained from the expression:
Pe=.4818(? B2mt2f2) watts per pound
?D
Where:
Bm is the maximum magnetic indudction in kilogauss
T is the laminations thickness in inches
? is the electrical Resistivity in microhm-cm
? is the so-called anomalous loss factor
Anomalous losses are introduced to account for differences between observed eddy-current losses and those calculated for the classical electrodynamics (in which case ?=1), and are usually attributed to magnetic domain wall effects. The deviation of the anomalous loss factor from the classical value of one increases with decreasing core loss and sheet thickness. (?=1 to ~ 2.25).
Total core loss is Ph + Pe
